4 members (JohnHarris, TalkMorgan, Graham, G4FUJ, jbk), 333 guests, and 93 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Page 1 of 4 1 2 3 4
#797023 05/03/24 11:21 AM
CJB Offline OP
What's the current thinking on lubricating leaf springs? Mine creak under torque.
1990 +8 Connaught Green
1970 Lotus Elan S4 SE
1973 Lotus Europa TC/Special
An aerosol can of motorcycle chain oil sprayed onto the edges of the leaves will penetrate most effectively. Get the one that is suitable for o-ring chains so as not to damage any rubber bushes.
I do mine just once a year.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
TBM Offline
As above - I use bike chain wax.
As a matter of interest which brands do you use?
I have got 4 or 5 part used spray oils in the garage and cannot find one that works.
2008 Plus 4 in Royal Ivory
I always use motorcycle chain lube.
Castrol, Halfords own brand or any from a good motorcycle dealer.
It penetrates when you apply and dries to a wax.
Works really well.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
I use fork lift chain spray, it stays on the metal and doesn't wash away easily, it also penetrates the leaves. Fork trucks usually work in a harsh industrial environment so if its good enough for them etc.
David Byrne
I use bike O ring chain spray. Cstrol is what I have on the shelf. applied once a year
Rog Offline
Definitely one of the best things you can do to improve the ride.
This is what I have done, not a recommendation but just for interest...
I first flushed my springs to drive out any iron oxide dust that had developed between the leafs with a pressurized can of cheap penetrating oil. You would be amazed at how much red debris came out. I then slackened the ubolt nuts and injected grease between the leafs before tightening as my creaking was mostly coming from the portion of spring directly below the axle. This was all done a while back but the ride is still superb and silent.
I do like silent springs so I’ve also cut access holes in the covers over the front bushes. When they start to squeak it’s a quick job to douche them in lube.
Roger
Best to jack up the rear of the car to reduce weight on the springs before squirting with bike chain lube via a long tube.
Leave it on jacks overnight to fully penetrate.
Removing the tool tray and spare wheel gives improved access.
Do this at least once a year.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
I've used Waxoyl for years, good creeping qualities, never dries....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Page 1 of 4 1 2 3 4
