9 members (piquet, vincentvg, IcePack, DJC, Craig Jezz, Cat302, DaveK, ChrisConvertible, gmcn),
337
Topics49,838
Posts837,295
Posts: 2,049 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,049 Likes: 12 |
It’s not a continuous clicking but one click/clunk then u have to release and push the starter again. Sometimes it can take 20 plus attempts for me
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 5,434 Likes: 466
Posts: 5,434 Likes: 466 |
From your description Viper, my guess would be that you have a variable resistance in your starter circuit the relay operated by the push button would perhaps be the first port of call...?
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
It’s not a continuous clicking but one click/clunk then u have to release and push the starter again. Sometimes it can take 20 plus attempts for me Probably a partially stuck piggyback solenoid Viper. Proof of this make come from a second person operating starter button whilst you lightly tap the solenoid itself with a soft hammer. If the motor then operates you have the culprit although nowadays it means a complete new/exchange starter motor as mentioned earlier. It doesn't sound like the starter relay as that makes a much lighter click although an easy check is with plug-in replacement if above reveals nothing.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
It’s not a continuous clicking but one click/clunk then u have to release and push the starter again. Sometimes it can take 20 plus attempts for me Last time this happened to a pals car, with similar symptoms I stripped the motor to find the brushes had worn so low that the commutator was damaged and full of carbon/copper goo, causing a sort of 'short out' of power & the battery struggled to rotate the motor
