Morgan Aero 8
6 members (B3MOG, IcePack, CooperMan, JMcL, PaulV, Morganmike), 251 guests, and 49 robots.
+8Rich 91
Topics49,841
Posts837,313
Page 5 of 5 1 2 3 4 5
Sir S1'a'lot
Sir S1'a'lot
It’s not a continuous clicking but one click/clunk then u have to release and push the starter again. Sometimes it can take 20 plus attempts for me
2002 Aero 8 S1
2023 Plus 4 (woman’s)
From your description Viper, my guess would be that you have a variable resistance in your starter circuit the relay operated by the push button would perhaps be the first port of call...?
Probably a partially stuck piggyback solenoid Viper. Proof of this make come from a second person operating starter button whilst you lightly tap the solenoid itself with a soft hammer. If the motor then operates you have the culprit although nowadays it means a complete new/exchange starter motor as mentioned earlier.
It doesn't sound like the starter relay as that makes a much lighter click although an easy check is with plug-in replacement if above reveals nothing.
Last time this happened to a pals car, with similar symptoms I stripped the motor to find the brushes had worn so low that the commutator was damaged and full of carbon/copper goo, causing a sort of 'short out' of power & the battery struggled to rotate the motor
