2 members (Brian Dearle, Morgan Dude), 325 guests, and 39 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
Hi everyone!
First of all: I am very new in the Morgan community and got my Morgan v6 3.0 2010 yesterday. It has a customised dashboard with old toggle switches. I tried them out and after I turned on the hazard it stopped working. Now the hazard light and the flashing lights (left and right) are not working anymore. Everything else works. Since I am very new I was hoping somebody can give me an advice?
Regards,
Michael
A picture of the dash Michael would help identify what you might have there! 2010 is bang in the middle of a problem PCB era but yours having a set of toggle switches fitted might mean that you have had a simplified system fitted. If so it might just be fuses/relays or connections. You might have to drop the dash to have a look at the rear...... don't panic, a hard pressed young mum with kid's could do that in 5 minutes!
RMP Offline
First check the the fuses,and then the earth wire, make sure it's not a" bad earth", and every connection is pushed in correctly.
RMP
Sounds like a fuse to me, much easier to check these before disturbing anything else
Yes check fuse 10 (15 amp) and replace if necessary. It also covers headlamp flash circuit so may be a clue if it's not working as well.
If that proves fruitless then as suggested above it may be a printed circuit board (PCB) issue. I'm also wondering if the dash switch replacement was fully checked. I believe the later PCB your car was fitted with used momentary (latching) switches.
X
X
Das hört sich nach Sicherung an. Da also zuerst ansetzen.
Wenn das öfter vorkommt würde ich da den Händler ansprechen.
Wenn ich das richtig sehe wurde das Auto auf einem Hänger geliefert? Oft gelangt im Regen Wasser in den Morgan, auch in den Bereich der Schalter. War ist das Auto innen in dem Bereich nass? Das würde ich dokumentieren und hilft für die künftige Vorgehensweise.
Neben dem klassischen „ich stelle das ab“ bauen findige Morganeers einen „Spritzschutz/Wasserableiter“ oberhalb der Instrumente hinter das Armaturenbrett. Wie gesagt, willkommen im Club.
Gruß René
2018 plus4 (sports green)
Hi Everyone!
Sorry for my late feedback and thank you so much for your help.
The car was delivered in a closed trailer and everything was working. The blinker was working but the sound was very fast and sounded a little bit suspicous to me but i dont know the "normal" sound of a blinker of a morgan v6 wink
I already changed the Fuse because that was also my first idea. Maybe all "extra" fuses are already broken as well because the former owner had the same issue and changed it or i maybe tried the wrong fuse. I will add a foto later of the fuse panel.
Here is a foto of the dash: https://ibb.co/TcQ9N1h
Regards,
Michael
First time I drove a Trad I was suprised at the (to me) high-pitched / fast / quite annoying blinker sound. My Roadster is the same so I'm guessing "they all do that Sir".
Hi Everyone!
Regards,
Michael
Michael, your dash insert with toggle switches is non-original, I would speak to the dealer & perhaps look through any documents that came with the car and try a find out who made the revised version and see if a revised wiring diagram is available
MK used to offer similar https://www.mk-holztechnik.de/englisch/about-mk/index.html
And perhaps Morgan Park https://www.morganpark.de/shop/
It looks like an MK one to me. I enquired for my S1 Roadster before it was t boned . From memory it uses the same pcb & connectors.
2025 MG ZS EV aka Trigger
