5 members (Pyewacket, DaveW, +8Rich, Black Adder, DJC), 298 guests, and 37 robots.
John V6 68
+8Rich 67
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,047
Captain Morgan, IRWIN
Page 4 of 4 1 2 3 4
Simon
I understand your concerns about the dashboard. I will probably use the plate of the radio compartment cover as a place for the switches.
I have a radio, never listen to it but don’t like to remove it
Simon
2002 4/4
2021 Audi A1 sport
I got a piece of wood and fitted them underneath radio. It’s just a thin piece of wood squeezed between the bottom of the radio and the gearbox tunnel but is firm and holds the switches well.
Sorry about quality of pic
There isn’t room under mine it’s tight between the under side of the heater and top of the tunnel
Simon
2002 4/4
2021 Audi A1 sport
Hi, I have just ordered a heated seat kit from EBay and was wondering, is it easier to insert the seat cushion heat pad from the rear? Also, looking at the fuse box I can see the heated seat fuse is a 20A fuse with a white and orange striped wire for my 2014 Plus4, did anyone find an existing connector block beneath the dash?
Finally, is recommended to install a barrier piece of material between the seat foam and the heat pad?
Appreciate any tips you may have.
Cheers
There are dedicated green and black (positive and negative respectively) wires under the dash for the heated seat supply, terminating in female bullet connectors according to wiring schematic Kenny. If you trace back ignition switch connector wiring to main loom these wires eminate from same breakout point. They are probably taped or tied out of the way if not used during build.
1 member likes this: KennyW
I wanted to do the same, not for me but for my wife.
But then I saw this.
A little more expensive but a lot less work.
The included cable with fuse directly from the battery to next to the seat.
Simply plug it in and don't forget to unplug before getting out.
Tested and approved by SWMBO last weekend.
She finds it much more efficient because the back, chest and arms are heated.
1990 4/4 1.6 Ford CVH Sold
2014 +4 2.0 Ford
2005 BMW Z4 2.2 6Cyl Sold
Page 4 of 4 1 2 3 4
