4 members (Gordon D, B3MOG, cerealsurfer, Doug J), 135 guests, and 64 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
Neil49 Offline OP
Hello everyone.
Our +4 was fitted with an easy-up hood, which entailed reversing the windscreen frame, so the old hood studs faced aft instead of forwards. Then they were removed and the holes brazed up. There was no time to do anything else at the time. We have covered the aft end of the frame with black tape and it worked OK until now, but we want to re-chrome the whole frame.
The option is to buy a new frame, remove the studs, and fit small plugs to the holes (facing aft as now).
Does anyone have experience of this, and what is the best way of sealing the windscreen in the frame afterwards?
+4 1986 - Royal Ivory / Blue
Volvo 123GT 1967 - Pearl White / Brown (pristine and very rare)
I have a spare windscreen and assembly from a 2005 car. Designed for the factory easy up.
Don't know if it would fit an earlier car...?
If you re-chrome the existing frame at least you will know everything will fit
Neil49 Offline OP
Yes Jon, I am thinking much the same. There is a good chrome shop in Sydney. Also to keep the vehicle as original as possible.
I have a smooth 2 seater windscreen frame that I fit on my Easy~fit~hood conversion. Not sure how much to send to you though.
Neil49 Offline OP
Thanks Steve, but after further thought I will have mine re-chromed. They can fill the small imperfections with brazing and based on other work they have done it will turn out well.
