0 members (), 330 guests, and 52 robots.
+8Rich 94
Posts837,276
Am I correct in assuming the only way to be certain about the condition of the actual clutch components except for the master cylinder and lines, is to remove the engine and physically inspect at that point? I am starting to believe this may actually be the master cylinder, however that opinion may be informed by my FEAR of engine removal and all that entails. I guess I’ll start to source the part later today, starting with M3wservices
Getting the engine in and out is not all that bad and you DO NOT HAVE TO CUT AWAY PLASTIC TRANSMISSION TUNNEL to get to all the bolts/nuts. I will look for a write up i did with photos.
I
I
I just ran into the same issue, and have inquired of M3W Services for purchase of a master cylinder. Does anyone know what the part number/ designation is, and if it can be purchased from a US auto parts supplier?
Have you checked out the alternative parts list on here ? link to clutch spares and original part numbers.
Thanks...that would be extremely helpful if I end up going there!!
I emailed Craig@m3Wservices with pn# U120071 Clutch Master Cylinder. Date of manufacture on my VIN plate is 12/13.
I hope it's that and you don't have to split the engine out.
Good luck..
Well after 2 days I still haven’t heard from Craig at M3WServices regarding the part. Using an alternative is likely beyond my abilities.
Toys for Boys
Toys for Boys
Will - I was talking to Craig today and mentioned your post - he's not on Talk Morgan, so asked me to tell you to check your junk mail as he responded the same day he received your email.
Omne trium perfectum
PLEASE everyone DISREGARD my message about Craig...he responded but it ended in my junk mail
I APOLOGIZE for this MISTAKE!!!
Will Stotts
