9 members (MartO, DCH, RedThree, +8Rich, High Hamster, jbk, RubyMog95, JohnHarris, James B W), 290 guests, and 105 robots.
+8Rich 76
Topics49,869
Posts837,664
Moggo
#800273 12/05/24 12:52 PM
SFG Offline OP
Does anyone else have squeaky headrests?
SFG
2012 4/4 Sport
SFG #800274 12/05/24 02:38 PM
If the noise is from the pillar a little silicone grease may help. This certainly aids removal.
SFG #800282 12/05/24 05:05 PM
SFG Offline OP
There are wear scratches on the column - I’m trying tape around it
SFG
2012 4/4 Sport
SFG #800303 13/05/24 06:54 AM
I would be very wary of applying tape to it. The pillars are necessarily a close fit and the tape will probably wrinkle off and could become entangled inside the seat . It could then jam things up altogether. Scratches on the pillars are common. Lubrication is the best approach; even a short squirt of wd40 down the hole may help the squeak.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
+1, or
Alternatively, you could use a small amount of leather cream, on the column.
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
SFG Offline OP
Too late.
How would it jam things altogether?
SFG
2012 4/4 Sport
SFG #800353 13/05/24 08:16 PM
The tape rolls up against the location point and then it jams, usually when trying to remove it and it wont come back out!
SFG #800408 15/05/24 02:44 PM
I used to put car wax on the stems of mine to make them slide easier. No punch in the face or a flying headrest then !
SFG #800440 16/05/24 10:49 AM
Vaseline! Works on babies bums and it works here too! Applied sparingly it won't contaminate the leather of the seat and most importantly it won't dry out. Apply it to the bottom half of the stem only and you will find that this will sort things out. Don't ever start squirting things like WD40 down the hole as it will soak into the seat back leather and leave a stain!
