6 members (sewin, Camelot, david nathan, chanteclair, Black Adder, MartinB60), 314 guests, and 34 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,018
RedThree
#801916 14/06/24 08:08 PM
Grumpy2 Offline OP
Can I give a shameless plug to my new favourite tool
https://amzn.eu/d/hopQWZO
Wifey bought me one of these a couple of months ago, initially unimpressed as it feels a bit cheap and toylike. My does it do a good job, must have used it 10 or 12 times on the same charge and the first disc. It’s cut bolts, stainless sheet, mild steel sheet, piano wire and most recently I managed to get it into and really tight spot to grind off a seized and rounded nut on the drip link of our golf.
Cracking little thing, highly recommended (hope the link works)
Grumpy2 #801941 15/06/24 07:39 AM
If it does the job, great…but maybe they are being a bit generous with the power output of 550 watts for a battery powered machine. That is equivalent to 30 amps at 18 volts. Expect the Chinese thought that would impress us no end!
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay #801985 15/06/24 10:18 PM
I can believe it... that would only be a 3000mAh battery running at 10C (ie 10x3 amps).
Here is a battery claiming to do 250-500 amps! (likely only for a few seconds mind you!)
Grumpy2 #801992 16/06/24 07:35 AM
Grumpy2 Offline OP
My 18v dewalt drill is rated at 460w so maybe the rating isn’t that fanciful. From memory there are many creative ways of rating power, I remember Amstrad used to rate their Hifi as peak-peak giving ludicrously high numbers despite the industry standard being RMS (blimey that’s got a few cogs ticking in my brain)
Nevertheless no matter what the real power is the tool does a much better job than I ever anticipated and I wouldn’t hesitate to recommend one to a friend or on here.
Grumpy2 #802067 17/06/24 02:17 PM
From experience working in the industrial power tool industry, the vast majority of battery and mains powered tools are made in China now. Even Hilti have outsourced some of their smaller products over the years and are not all made in Liechtenstein.The advancement in battery tool technology is amazing now, and even cheap range products are very good for the home workshop.
Grumpy2 #802093 17/06/24 07:51 PM
Grumpy 2 if my memory is correct RMS = .707 of the peak value... ie 100watts peak = 70.7 watts RMS
David Byrne
Grumpy2 #802094 17/06/24 08:37 PM
2009 4/4 Henrietta
1993 Connaught Green +8 prev
B3MOG #802103 18/06/24 07:50 AM
Grumpy2 Offline OP
David Byrne
Yep my cogs have been turning too, root of 2 = 1.414, reciprocal 0.707, hence RMS. I always admired Alan Sugars use of peak-peak marketing ; take the standard RMS, multiply it by 1.414 to get a peak value then double it to get peak to peak! Big numbers were impressive in the 70s
Finally exhausted my first battery yesterday. Cutting 2mm sheet to make 6 hinge brackets. I remain very impressed with my super tool!
Grumpy2 #802115 18/06/24 12:15 PM
Little experience with rechargeable tools but googling about…you guys are right…500+ watts is indeed attainable from a 18 v battery.
I stand corrected.
Doug
1958 Triton 650
Fuel.inj #802176 19/06/24 09:10 PM
miles of smiles
miles of smiles
The majority yes, except Makita have a manufacturing factory in Telford, if you check an up to date Makita product guide you’ll see a Union Jack adjacent to the Model number of the British made tools, they also built their newest state of the art manufacturing plant in Romania.
Not wanting to dampen the enthusiasm, I know it’s futile, but I refuse to buy anything from Amazon, the world was a better place without the cheapskate leeching business, any money spent with tax dodging Bazos helps only him.
