8 members (JMcL, Arwyn Williams, DPEvans, GrumpyPa, DaveW, JohnHarris, +8Rich, Burgundymog),
220
60
Posts837,257
Posts: 72 |
What is the best/recommended brake/clutch fluid for the M3W
Gordon
2013 M3W 1972 MGB Roaster 1967 Morris Mini Super Delux
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
DOT 3 will do, DOT 4 is maybe a bit better, the fluid doesn't lead a particularly hard life unless you drive it with the handbrake on. DOT5.1 is also fine.
Don't use DOT 5, the silicone fluid, it's not compatible with what is in there an might be incompatible with some of the seals in the system.
Posts: 72 |
Gordon
Posts: 72 |
About to change the brake and clutch fluid on my M3W.
DOT 4 is recommended. Most available seem to be Synthetic is this the correct type or do I need to seek out a Glycol based fluid?
Gordon
Gordon
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Any fluid made to DOT4 spec will be compatible with the machine. So called synthetic brake fluids are glycol based (i.e. PEG-polyethylene glycol), but have performance enhancing additives to increase boiling point, reduce the impact of water absorption, reduce corrosion, etc.
Steve Late 2012 M3W
Posts: 72 |
Gordon
Posts: 72 |
Gordon
