4 members (John Winn, Matt C, +8Rich, Clipper), 264 guests, and 33 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,333
Christoph
#802871 03/07/24 06:40 PM
HIND Offline OP
What is the best/recommended brake/clutch fluid for the M3W
Gordon
2013 M3W
1972 MGB Roaster
1967 Morris Mini Super Delux
DOT 3 will do, DOT 4 is maybe a bit better, the fluid doesn't lead a particularly hard life unless you drive it with the handbrake on. DOT5.1 is also fine.
Don't use DOT 5, the silicone fluid, it's not compatible with what is in there an might be incompatible with some of the seals in the system.
HIND Offline OP
Thanks Calum
Gordon
2013 M3W
1972 MGB Roaster
HIND Offline OP
About to change the brake and clutch fluid on my M3W.
DOT 4 is recommended. Most available seem to be Synthetic is this the correct type or do I need to seek out a Glycol based fluid?
Gordon
Gordon
2013 M3W
1972 MGB Roaster
Any fluid made to DOT4 spec will be compatible with the machine. So called synthetic brake fluids are glycol based (i.e. PEG-polyethylene glycol), but have performance enhancing additives to increase boiling point, reduce the impact of water absorption, reduce corrosion, etc.
Late 2012 M3W
HIND Offline OP
Thanks Steve
Gordon
2013 M3W
1972 MGB Roaster
HIND Offline OP
Thanks Steve
Gordon
2013 M3W
1972 MGB Roaster
