1 members (Bitsobrits), 322 guests, and 38 robots.
+8Rich 94
Posts837,276
Page 3 of 3 1 2 3
If nothing else get the garage who service it to remove & replace the wires annually & grease the splines. They should do that to check on the brakes.
The wheels really need to come off to clean properly. MWS do a good cleaning kit but it is v expensive
I find it weird that MMC advise against a one point jack to change a wheel, you're bu66ered for a DIY roadside puncture & would the AA man think you were balmy pointing it out ?
Is the CX chassis so weak ? What if you drop into a big pothole ? What about a steep twisty ramp onto a ferry ? surely there are lots of 'normal' situations that subject the chassis to high point loads ?
I thought at launch MMC bragged it had more torsional stiffness than the Aero chassis ? The bonding glues used produce a joint stronger than the material...so is this admission that the alloy is a bit low grade ?
What's the restrictive jacking info for a modern Lotus, as ex Lotus lads designed the CX chassis (allegedly)
Well if you have a puncture, the chassis has already been subjected to uneven stress, so jacking it up just enough to change a wheel seems unlikely to be an issue.
I am wondering whether there is some mis-interpretation of the manual here. Maybe it is meaning not to jack it up in the air beyond normal height at a single point to say, gain bodily access beneath the car. etc? I haven’t checked my manual but have a feeling that I have seen a similar statement for trads, yet they were still provided with a scissors jack.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Page 63 of the MY23 handbook gives information on lifting the car. There are reinforced points which should be used with a single jack.
Originally Posted by Jon G4LJW
Note the Plus Four link for 2020 onwards take syou to the Plus Six and vice versa crazy2
Doh!
Page 3 of 3 1 2 3
