1 members (Morganmike), 149 guests, and 59 robots.
+8Rich 94
Posts837,276
#803553 14/07/24 08:01 PM
Does anyone know how to adjust the clock? Having disconnected the battery it is now “stuck” on 12:00.
Tim Rice #803567 15/07/24 06:27 AM
Press and hold the button on the end of the indicator stalk until the hours flash. Then short presses to cycle through the hours until correct.
Release button for a second or so then long press to select minutes. Cycle through until correct then release button followed by long press to exit setting mode.
Red Leader drive
1 member likes this: Bunny
Chris99 #803580 15/07/24 09:46 AM
Thank you very much.
Tim
Tim Rice #807055 04/09/24 11:40 PM
Am I wrong in asking…Doesn’t the clock need resetting every time you start the M3W? My Brooklands edition (2014) requires it.
Will
Will
Providing the battery has not been disconnected the clock should retain its settings.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Tim Rice #807062 05/09/24 07:14 AM
Clock, clock!
What sort of modern contrivance is that?
doh
Bud
4/4 - Stanley
Bud
4/4 "Stanley"
Will
It sounds like the factory or a PO has inadvertently connected clock to ignition controlled feed. I would suspect the latter if you haven't owned the car from new, since the main loom provides a keep alive feed for clock.
Tim Rice #807093 05/09/24 12:12 PM
I know it's not an answer to the question posed, but I've one of these little CHAPS fitted. Wouldn't be without it now.
Andy
1 member likes this: Bitsobrits
Tim Rice #807274 08/09/24 10:29 AM
Oxford clock was my solution, its stick on but can fall off occasionally without harming the leather.
