0 members (),
308
46
Posts837,277
Posts: 14 |
Rear N/S indicator suddenly stoped working at the end of a short run. On investigation it seems that the small orange gasket/ contact behind the bulb has lost the small metal contact . Any remedy short of buying a new light unit for mega bucks.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Pull the wire back through and solder a small washer on the end (some forceps to hold it are helpful) you may then need to make a little insulating ring which is usually the collapsed bit
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
If that doesn't work a complete unit is not that expensive as it's a standard Lucas item. Holden have them here
Posts: 14 |
Fiddling about last night, now nothing works.checked all the 7.5 amp fuses all ok. Could it be the relay, if so where are they?
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
On the pcb if like the roadster
Posts: 651 Likes: 12
Posts: 651 Likes: 12 |
Fiddling about last night, now nothing works.checked all the 7.5 amp fuses all ok. Could it be the relay, if so where are they? The original rubber hoses to the windscreen washers are of poor quality. If you have used anti-freeze windscreen washer fluid, they may have disintegrated and caused a leak onto the PCB behind the dash. Harald
Harald +4 4-seater 2008 Squadron Blue
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Fiddling about last night, now nothing works.checked all the 7.5 amp fuses all ok. Could it be the relay, if so where are they? Be useful to expand on “nothing works”
The indicator circuit is protected by a 15 amp fuse 10. It also covers headlamp flash. Could it be that your repair has created a short and blown it?
The indicator flasher relays for individual indicators and hazard lights are embedded in a PCB module behind the dash. If however as your first post suggests, it was only the rear n/s indication that failed and you found fault with the bulb connection then unlikely to be the relay.
