0 members (),
257
100
Topics49,847
Posts837,389
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
The modern equivalent .... 2x Hyabusa top ends on a custom block ..... not as pretty as the '40s version but at around 500bhp and weighing 100kg it's the sort of motor that pushes modern hillclimb single-seaters to the times they get! ![[Linked Image]](https://www.tm-img.com/images/2024/07/09/Screenshot_20240709_141854_Chrome.jpg) K
Benelli .... V8 250cc !! 😮 ..... built in 1968 .... never raced because the FIM then restricted 250s to twin-cylinder .... imagine how gutting it must have been to hear that news after building this little jewel! ![[Linked Image]](https://www.tm-img.com/images/2024/07/18/FB_IMG_1721237370825.jpg) K
1 member likes this:
Graham, G4FUJ |
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
An engineering artwork Keith!
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
![[Linked Image]](https://tm-img.com/images/2024/07/20/herc.jpg) In keeping with the D-Day anniversary, here is an archive photo of the valve-timing gears from the Bristol Hercules radial engine. This was a 14-cylinder two-row radial sleeve aero engine produced by the Bristol Engine Company starting in 1939. It powered the Bristol Beaufighter heavy fighter, and was commonly used on British bombers at the time. This engine was designed on drawing boards, using manual drawing instruments and 2D orthogonal projections. No 3D solids, no CAD simulations to check for geometric interference. Respect..
2 members like this:
Graham, G4FUJ, bmgermany |
Posts: 11,526 Likes: 312
Posts: 11,526 Likes: 312 |
There is a field engineer somewhere swearing as they see this image
+8Rich |
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
![[Linked Image]](https://tm-img.com/images/2024/07/20/herc.jpg) In keeping with the D-Day anniversary, here is an archive photo of the valve-timing gears from the Bristol Hercules radial engine. This was a 14-cylinder two-row radial sleeve aero engine produced by the Bristol Engine Company starting in 1939. It powered the Bristol Beaufighter heavy fighter, and was commonly used on British bombers at the time. This engine was designed on drawing boards, using manual drawing instruments and 2D orthogonal projections. No 3D solids, no CAD simulations to check for geometric interference. Respect.. Also no CNC machines to mark up and cut the gearwheels either, just proper hands on machinists, perhaps assisted with a slide rule and a sharp 4H pencil
![[Linked Image]](https://tm-img.com/images/2024/07/20/herc.jpg) In keeping with the D-Day anniversary, here is an archive photo of the valve-timing gears from the Bristol Hercules radial engine. This was a 14-cylinder two-row radial sleeve aero engine produced by the Bristol Engine Company starting in 1939. It powered the Bristol Beaufighter heavy fighter, and was commonly used on British bombers at the time. This engine was designed on drawing boards, using manual drawing instruments and 2D orthogonal projections. No 3D solids, no CAD simulations to check for geometric interference. Respect.. Also no CNC machines to mark up and cut the gearwheels either, just proper hands on machinists, perhaps assisted with a slide rule and a sharp 4H pencil Those were the days of my youth, back to the Technical Drawing Classes, you forgot the Log Tables going back a bit Jon. These were true craftsmen and women back in those days. Who knows as MMC produced fine engineering during the WWII era maybe they made some bits.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
I think mmc made landing gear. I remember tech drawing at Uni in the 70s, the. Cad in the 80s being such a great tool.
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
I think mmc made landing gear. I remember tech drawing at Uni in the 70s, the. Cad in the 80s being such a great tool. I did technical drawing at school in the '70s, I flipping loved it, I'd have been perfectly happy to go down the CAD/CAM engineering route if someone had pointed me in that direction, sadly my school was a traditional English grammar that looked down its nose at engineers. Twats.
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
sadly my school was a traditional English grammar that looked down its nose at engineers. Twats.  I started out in the drawing office with a defense contractor in the 70’s. A huge office full of engineers and draughtsmen. Working on the drawing board was a delight but a completely different skill set compared today’s CAD. So much skill has been lost that will never be seen again. Gear chains were always fun. The amount of hand calcs and stress work that went along with any design was daunting but all done in an instance now on a computer without a second thought. When you got it wrong there was no delete or back button. You could only make so many changes to your layout before your rubber destroyed your 'work of art' that you might have been working on for weeks. The scary part was always waiting for that dreaded phone call from the workshop or assembly when the first proto was manufactured. “We have a little problem, could you pop down and take a look…..” But there was at least one good thing about the move to CAD. At least I had a loft space boarded out with redundant A0 drawing boards
Roger 2011 Plus 4
