If there is one chap who has great experience in polishing Trad Morgans, it is Mr GoMoG ( Lorne) who despite many thousands of miles covered, every aspect of his Morgan is polished like a new pin, though from memory he has chrome bumpers... naturally... (-:
I admit to being besotted with shiny metal. The right choices never fail you like paint or chrome always will.
Two of my Plus 8, came set up like yours, with the open ended alloys. Aluminum can be polished
somewhat, but even a professional job, aside from the new electrolyte polishing, produces a lustre finish rather than a mirror finish. On my first car I was able to have the original bumpers chromed, a careful triple
plating/polishing job with alloy.
I gave my last one to the late John Sheally II. He was even more of a shiny metal nut than I!I came to like the closed ended ss bumpers that came with my recreated my mog in 2002. Polished ss is not quite as lovely as chrome, but it can be
mirror polished. BTW, very recently, Achim G found he was
able to use a skilled fellow with a 30 ton press to make a dented stainless bumper perfect again for 40 pounds..a saving of 900 pounds. So switched both my +8s to polished stainless bumpers in front but I use
and the
original Morgan chromed steel overriders at the rear, not the later ones. On request, the Factory had made my Morgan slimmer than the norm. The standard bumpers of the day were too wide and I had
learned to be wary of them.
BTW, as is obvious at a glance, trad bumpers are merely decorative. They offer no protection and even (especially at the rear) add to risks and damage, unless remedial measures are taken. Trust me. As you know,
have detailed experience with that.
The overseas' bracketry offers production but I prefer the UK stock look. Bumpers/overriders, compliment the Morgan looks.
Which was a too long route to get to the subject at hand. (wryly)
In front, there are two types of bumper brackets. The painted tubular curly things AND the shaped aluminum ones, either in rough metal or painted from the aftermarket. (both below) The original tubular ones were
roughly painted, but later, (aka now) they can be had in polished stainless. The last are the ones I settled on. I did once try to polish the aluminum ones (dealers call them the "flat types") but it will not give one a mirror
shine. I use either professionals polishers or table grinder mounted polishers.
I have seen some very decent results for aluminum using baking soda and a polishing pad at the end of a hand drill.Both types of stock bumper brackets break, unless you don't use your car much. The weight of the bumpers interacts sadly with the bouncing up and down and they shear at the stress point at the bolt. I made discrete
welded reinforcements for both (I have both types, one in spares) that has been fine for 25 years on all three mogs. I no longer use the overseas configuration, even on the cdn car.
The MMC and I came up with
something more discrete and suited to the car that offers the production one needs. They used it since on occasion.
Please note, I DO NOT replace Morgan stuff that breaks. I take failure as indisputable evidence that the same guilty part will break again, possibly 1000s of miles from home. I think it out, ask around and make or modify
it for something more reliable. It makes for bullet-proof Morgans.
Lastly, I have never had problems with rear bumper brackets of any type. I use John Worrall polished stainless bracketry on all mogs. It doesn't rust.
L.
![[Linked Image]](http://www.gomog.com/TEMP/FrontBumperBracketTypes.jpg)
