Topics48,362
Posts813,325
Members9,215
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
Exactly. I don't think it can be old fuel after 1600 miles But today after adding Redex it seems well reduced. Thnking about it the car did c 700 miles from May 22 till Aug 23 so around 46 miles per month. From Aug 23 till June 24 it did c 200 miles so 20 miles per month. It might need more time to flush out and crud.
Posts: 193 Likes: 5
Posts: 193 Likes: 5 |
I advise you to use an injection circuit cleaner. I do it systematically every year.
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Exactly. I don't think it can be old fuel after 1600 miles But today after adding Redex it seems well reduced. Thnking about it the car did c 700 miles from May 22 till Aug 23 so around 46 miles per month. From Aug 23 till June 24 it did c 200 miles so 20 miles per month. It might need more time to flush out and crud. Just a thought John, is the dealer ok to share the service / warranty items the previous owner had the car back to them for work on ?
I'm sure Krazy Horse can check that on Wed
I have via the selling agent contacted the original owner. He confirms no pinking noise so I suspect old fuel. The brakes he says were sorted.
So KH gave the car the once over today and thank god they did. There was a potentially dangerous fault, now fixed and it needs a new rad which is going to be fitted 15/8.
The rear noise was the exhaust vibrating on the tub. The pinking is old fuel & is going away.
Posts: 4,608 Likes: 14
Posts: 4,608 Likes: 14 |
Afternoon John - one of our ThamesMOG members are onto their third CX rad......
Steve, as I understand it the rad maker forced MMC to use up the older design units which then of course failed. Now they use an updated design. Mine is the original unit but according to the selling dealer had been sorted. Not so it seems. The upside will be that latest design with associated better software.
Posts: 1,177 Likes: 17
Posts: 1,177 Likes: 17 |
Intriguing “dangerous fault” can you say what as some might like to take a look at theirs.
I'd prefer not to for now. I would be very surprised if others have this .
