Topics49,837
Posts837,288
Posts: 4 |
Hi everyone, can anyone give me some advice on how to dismantle the windscreen on my 3 wheeler. I have removed all the screws and bolts. There is still the silicone glue that holds the windscreen in place. Thank you for your advice
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
You need to slice through the silicone sealant with a long thin blade, then it should come out. The sealant should not be more than a few mm deep.
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
- no experience of the 3 wheeler ,per se, but dental floss or strong nylon fishing line is my usual for 'sawing' through set silicone. It has the added advantage of not causing scratches - as a blade might.....  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
1 member likes this:
PaulM3W |
Posts: 4 |
Thank you for your information
