2 members (Vansrv6, BHV), 295 guests, and 23 robots.
+8Rich 92
Posts837,277
#805235 09/08/24 06:18 AM
M3WB Offline OP
Hi everyone, can anyone give me some advice on how to dismantle the windscreen on my 3 wheeler. I have removed all the screws and bolts.
There is still the silicone glue that holds the windscreen in place. Thank you for your advice
You need to slice through the silicone sealant with a long thin blade, then it should come out. The sealant should not be more than a few mm deep.
- no experience of the 3 wheeler ,per se, but dental floss or strong nylon fishing line is my usual for 'sawing' through set silicone.
It has the added advantage of not causing scratches - as a blade might..... thumbs
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
1 member likes this: PaulM3W
M3WB Offline OP
Thank you for your information
