Removing the windscreen
3 members (
bmgermany
TBM
), 407 guests, and 49 robots.
by stumog - 26/08/26 10:24 AM
Christoph
August
805235
09/08/24
06:18 AM
May 2020
Belgium
M3WB
M3WB
May 2020
Belgium
Hi everyone, can anyone give me some advice on how to dismantle the windscreen on my 3 wheeler. I have removed all the screws and bolts.
There is still the silicone glue that holds the windscreen in place. Thank you for your advice
Re: Removing the windscreen
M3WB
805236
09/08/24
07:03 AM
Jun 2012
United Kingdom, Lincolnshire
planenut
planenut
Jun 2012
You need to slice through the silicone sealant with a long thin blade, then it should come out. The sealant should not be more than a few mm deep.
M3WB
805238
09/08/24
07:31 AM
Jul 2014
Newcastle Upon Tyne
James B W
James B W
Jul 2014
Newcastle Upon Tyne
- no experience of the 3 wheeler ,per se, but dental floss or strong nylon fishing line is my usual for
'sawing'
through set silicone.
It has the added advantage of not causing scratches - as a blade might.....
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
1 member likes this
PaulM3W
planenut
805245
09/08/24
10:36 AM
May 2020
Belgium
M3WB
M3WB
May 2020
Belgium
Thank you for your information
Switch to Threaded Mode
