4 members (gmcn, Pigiron, Craig Jezz, sbarracl), 222 guests, and 46 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,336
Christoph
Page 3 of 4 1 2 3 4
p8mog #805447 12/08/24 05:27 PM
Many thanks for your contributions today, which I have passed on to my friend. He is very grateful to hear that he is not alone with this fault.
He has now visited a Morgan dealer who got investigating straight away.
They discovered quite a list of stored fault information, none of which the owner was aware had ever occurred!
In line with the new warranty policy, a report has now been sent to the factory, and they are awaiting reply as to what is to be done.
It seems that several customers have had the overseer module replaced, but personally, I am still at a loss to understand its function on a manual car.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
p8mog #805450 12/08/24 06:06 PM
Me too, but I guess they have a standard ECU & it exist even for manuals
p8mog #805477 13/08/24 08:45 AM
When I had the rad upgrade at the factory Mark told me the car will need to come back every couple of years for a plug in upgrade as he new I did my own servicing.no doubt to also monitor the fault codes. This overseer switch does niggle me a bit to be honest and something out of your control and not really needed. Em
p8mog #806038 22/08/24 12:14 PM
I had an issue on my 21CX auto with the Overseer warning. The car was almost completely dead with only the wipers working and an Overseer warning light. Fortunately a resourceful local garage ( I was in Italy) identified the problem as a poor connection on the fuse board, he explain there were two halves to the fuse board and it was the live connection between these that was loose. Issue has never returned.
Roger
2021CX Plus four Auto.
p8mog #822478 25/04/25 11:11 AM
I
ITP Offline
I
I recently bought a CX plus 4 and had an issue with the Overseer warning illuminating with no effect on the car and then disappearing on restart. There was little guidance in the handbook about the function or operation of this rather oddly named device. I took the car to Morgan and a module was replaced curing the fault. I was unable to find anyone who could explain the function of this device to me but the factory have sent me this explanation below which I thought might be of interest.
Why the Overseer is fitted?
Our ECU and Engine suppliers both stipulate that for safety reasons that there must be a way of monitoring un-intended acceleration in the event that an engine ECU malfunctions. This is in accordance with Automotive Safety Integrity Level (ASIL) as defined by the ISO 26262 Functional Safety for Road Vehicles standard.
Our supplier also stipulates that for automatic vehicles the vehicle must detect rear wheel lock-up, which is designed to prevent damage to the automatic transmission, driveline and engine in the event that the rear wheels are locked.
How does the Overseer work?
The Overseer is fitted behind the dashboard in the centre line of the vehicle. The Overseer has two accelerometers built inside the module which monitor the X and Y axis of the vehicle (left to right/up and down). These sensors are calibrated in the Overseer with the diagnostic tool with the vehicle on flat level ground. Once calibrated correctly, both accelerometers will read zero.
The throttle pedal in the vehicle is connected to both the Overseer and engine ECU. The Overseer is also connected via a CAN network to the engine ECU.
The Overseer is constantly monitoring the X and Y axis accelerometers and the throttle pedal. In the event that the Overseer detects the vehicle accelerating via the X and Y accelerometers and see's that there is no throttle pedal input from the driver, the Overseer assumes this is an un-intended acceleration event. The Overseer instantly sends a shutdown request via the CAN network to the engine ECU which shuts down instantly, resulting in the engine cutting out stopping the un-intended acceleration. If this does happen a fault code is stored in the Overseer.
To prevent rear wheel lock-up, the Overseer receives information via the CAN network on each individual wheel speed. The Overseer monitors the front wheel speeds and compares them to the rear wheel speeds. If there is a great difference in speed comparing the front wheels to the rear wheels (which are locked) the Overseer sends a command to the automatic transmission via the CAN network which instantly puts the automatic transmission in neutral preventing any un-wanted damage.
Why does my Overseer light come on?
Due to the Functional Safety requirements, the Overseer must warn the driver in the event of an issue. The Overseer is required to store individual fault codes for each type of failure. The Overseer accelerometers sometimes do require recalibrating and often this is the cause of the warning light illuminating. Re-calibrating the sensors on a flat level ground with the diagnostic tool will clear the warning light.
ITP
4/4 80th Edition (Sold)
Plus 4 X 2022
p8mog #822479 25/04/25 11:29 AM
Thanks for posting. This is very helpful to understand the Overseer function.
I had the same problem and I also had a control module replaced.
Clemens
PlusFour Red Baron MY 2022
p8mog #822481 25/04/25 11:58 AM
Good explanation but why is a button under the dash board to desactivate the OS . If you go on a racetrack an you disable the OS you could damage the auto box ?
p8mog #822486 25/04/25 02:03 PM
It also come on on a manual if the battery fails
p8mog #822489 25/04/25 02:40 PM
Now I understand! I did have some fragmented knowledge. As I have a manual PlusFour it's not applicable for me!?
Ruut Bianchi
Yes, it actually does apply to you too. Look back about 16 threads to my thread #805374 dated 12/08/2024
Doug
1958 Triton 650
Page 3 of 4 1 2 3 4
