2 members (TBM, Montegue),
249
47
Posts837,277
Posts: 23 |
Does anyone know how to adjust the clock? Having disconnected the battery it is now “stuck” on 12:00.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Press and hold the button on the end of the indicator stalk until the hours flash. Then short presses to cycle through the hours until correct. Release button for a second or so then long press to select minutes. Cycle through until correct then release button followed by long press to exit setting mode.
Red Leader
1 member likes this:
Bunny |
Posts: 23 |
Posts: 67 Likes: 4
Posts: 67 Likes: 4 |
Am I wrong in asking…Doesn’t the clock need resetting every time you start the M3W? My Brooklands edition (2014) requires it.
Will
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Will Providing the battery has not been disconnected the clock should retain its settings.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Does anyone know how to adjust the clock? Having disconnected the battery it is now “stuck” on 12:00. Clock, clock! What sort of modern contrivance is that?  Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Will It sounds like the factory or a PO has inadvertently connected clock to ignition controlled feed. I would suspect the latter if you haven't owned the car from new, since the main loom provides a keep alive feed for clock.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I know it's not an answer to the question posed, but I've one of these little CHAPS fitted. Wouldn't be without it now. ![[Linked Image]](http://tm-img.com/images/2024/09/05/Oxford-Clock.jpeg)
Andy
Bitsobrits |
Posts: 1,947 |
Oxford clock was my solution, its stick on but can fall off occasionally without harming the leather.
