Morgan Aero 8
8 members (MATTMOG, tommog, John Winn, +8Rich, Jon G4LJW, nick w, Graham, G4FUJ, mph), 311 guests, and 43 robots.
John V6 71
DaveW 67
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,990
RedThree
#808963 05/10/24 09:06 PM
AeroIan Offline OP
Hi everyone, my heater is stuck on hot and the electronic control seems to be at fault. Has anyone any idea for replacement/ fixes/ had similar issues?
Aerolan. The heater in the S1 is quite a simple one there is no adjustment for control from memory. The round knob is just a switch or thats how it seemed to work on mine. The unit looks mechanical to work off elecric a few squirts of WD might be worth lt. Iv'e never seen a car generate so much heat under the bonnet as the S1 did. If you decide to pop the dash back you will have very little space to get at the switch all the cableing is so tight and some very sharp edges. Good luck hope its an easy fix. Em
AeroIan Offline OP
Taff in this case the fault is the knob that controls hot and cold does not move the blend flap in the heater box. So the heater is stuck on hot.
is there a way of testing the wiring/knobs etc?
Gonna have to get my way into heaterbox somehow. It all looks bonded together.
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
If it is like the trads it uses a Bowden cable from the knob and maybe that is undone at the knob.
Here are some photos of my old Roadster's controls & the heater control quadrant.
2025 MG ZS EV aka Trigger
Aerolan. If it is the switch try car builder solutions, you rally need to keep that knob on the best dash Morgan ever produced. Em
AeroIan Offline OP
Thanks guys
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
I find that this is handy stuff for cleaning e.g. switch contacts -
Contact Cleaner
- useful stuff to have around and a can will last you for ages.... thumbs
James
Mercedes EQC 400 AMG
Smart Brabus Convertible
Honda Monkey Z125
Sadly the Aero doesn't have Bowden cable operated heater flaps. This screenshot from parts book shows just rotary switches and/or potentiometers. It's all appears to be electrically controlled therefore. Note there is one control that selects fresh or re-circulating air.
AeroIan Offline OP
Thanks again … that’s the problem if the electronics/ pentiometer have failed. If anyone knows about replacements let me know
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
AeroIan Offline OP
Great job by Rick Henning of Rick’s Garage … in his words: Stripped the heater box, got the blend motor and worked out the problem, managed to make a wee bracket and sort out the fault etc. all good now sir.
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
