8 members (James B W, Image, Robbie, Liam1961, nick w, MJF, Pittsartist, John Wilcox),
230
65
Posts837,271
Posts: 20 Likes: 1
Posts: 20 Likes: 1 |
My car, a ‘22 Plus Four bought directly from Morgan factory, has a Banner battery fitted. Not had any starting problems but do keep it on a Ctek if the car is not used for longer than a week.
2022 CX Plus Four Manual - Rouge Delage
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Trouble is the bmw cars with this engine has the same. Maybe the OS module requires it. It would be interesting to know if any brave would has gone the cheaper route I would suspect the charge parameters built into all the BMW electronics and the alternator are set up for an AGM battery, you can't even swop some batteries like for like in 'moderns' without a laptop reflash RichardV6 may chip in with some sage advice...
Posts: 245 Likes: 5
Posts: 245 Likes: 5 |
I suspect its AGM because they dont leak and dont require a vent tube as battery acid will eat aluminum for breakfast,
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Arent calcium gel batteries non venting?
Posts: 20 Likes: 1
My car, a ‘22 Plus Four bought directly from Morgan factory, has a Banner battery fitted. Not had any starting problems but do keep it on a Ctek if the car is not used for longer than a week. Not sure quoting oneself is correct etiquette but felt compelled to highlight my own ignorance. I thought AGM was a brand of battery, not a type, hence prattling on about mine being a Banner one. I have enlightened myself.
Posts: 5,432 Likes: 466
Posts: 5,432 Likes: 466 |
Every day has the potential to be a school day has it not Marcher, I do quite a lot of learning on TM, and even more re-learning so many of the things I fail to remember...
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Every day has the potential to be a school day has it not Marcher, I do quite a lot of learning on TM, and even more re-learning so many of the things I fail to remember...  I have a Banner too in my PlusFour, and Avons as tires, all completely non-continental  . A well known advertisement in Holland used to be, in case of non-starting, it cannot be the battery, because that's a Varta! In my 4/4 I have a normal Duracell lead-battery, because Duracell goes on, and on, and on, etc.....!!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 8,656 Likes: 407
Posts: 8,656 Likes: 407 |
Arent calcium gel batteries non venting? Possibly VRLA John - valve regulated.
Ok. Every day a school day
Posts: 4,646 Likes: 123
Posts: 4,646 Likes: 123 |
Had a non start goose chase recently but learned that the battery was too low due to a poor connection on the charger.
Realised that I can view the battery charge level on my phone via the MMC fitted tracker app which is useful.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
