8 members (Rog G, Rex_tulips, Gordon D, linklaw, Dek, brownbaker, Mark Simmons, Mike D),
314
42
New
Topics48,365
Posts813,379
Members9,215
Posts: 19 Likes: 1
Posts: 19 Likes: 1 |
My car, a ‘22 Plus Four bought directly from Morgan factory, has a Banner battery fitted. Not had any starting problems but do keep it on a Ctek if the car is not used for longer than a week.
2022 CX Plus Four Manual - Rouge Delage
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Trouble is the bmw cars with this engine has the same. Maybe the OS module requires it. It would be interesting to know if any brave would has gone the cheaper route I would suspect the charge parameters built into all the BMW electronics and the alternator are set up for an AGM battery, you can't even swop some batteries like for like in 'moderns' without a laptop reflash RichardV6 may chip in with some sage advice...
Posts: 240 Likes: 4
Posts: 240 Likes: 4 |
I suspect its AGM because they dont leak and dont require a vent tube as battery acid will eat aluminum for breakfast,
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
Arent calcium gel batteries non venting?
Posts: 19 Likes: 1
My car, a ‘22 Plus Four bought directly from Morgan factory, has a Banner battery fitted. Not had any starting problems but do keep it on a Ctek if the car is not used for longer than a week. Not sure quoting oneself is correct etiquette but felt compelled to highlight my own ignorance. I thought AGM was a brand of battery, not a type, hence prattling on about mine being a Banner one. I have enlightened myself.
Posts: 4,614 Likes: 194
Posts: 4,614 Likes: 194 |
Every day has the potential to be a school day has it not Marcher, I do quite a lot of learning on TM, and even more re-learning so many of the things I fail to remember...
Posts: 1,702 Likes: 105
Posts: 1,702 Likes: 105 |
Every day has the potential to be a school day has it not Marcher, I do quite a lot of learning on TM, and even more re-learning so many of the things I fail to remember...  I have a Banner too in my PlusFour, and Avons as tires, all completely non-continental  . A well known advertisement in Holland used to be, in case of non-starting, it cannot be the battery, because that's a Varta! In my 4/4 I have a normal Duracell lead-battery, because Duracell goes on, and on, and on, etc.....!!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 7,944 Likes: 218
Posts: 7,944 Likes: 218 |
Arent calcium gel batteries non venting? Possibly VRLA John - valve regulated.
Ok. Every day a school day
Posts: 4,491 Likes: 65
Posts: 4,491 Likes: 65 |
Had a non start goose chase recently but learned that the battery was too low due to a poor connection on the charger.
Realised that I can view the battery charge level on my phone via the MMC fitted tracker app which is useful.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
