0 members (),
297
33
Topics49,841
Posts837,323
Posts: 19 Likes: 1
Posts: 19 Likes: 1 |
Any recommendations for a suitable glue to stick the U shaped seal into the head-rail of our Roadster. Evostick won't do as the seal needs to be slid into place and a contact adhesive will bond immediately on contact. And I reckon that cyanoacrylate (superglue) will be too brittle.
2006 4 str Roadster 1934 Super Sports 1935 F2
Posts: 1,463 Likes: 98
Posts: 1,463 Likes: 98 |
You need a thixoropic contact adhesive. Screwfix etc. I’ve used several types, it’s a bit like normal contact adhesive but allows slippage before pressure forms the bond. This might do the job. Although check it’s solvent based and not water based. https://amzn.eu/d/bT5HFc1
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
Are you sure you need to glue the seal. When I replaced my screen the seal was just pushed into place by the glass.
1956 Plus 4 4 seater
Posts: 19 Likes: 1
Grumpy, Your '56 +4 will have a row of lift-a-dot fasteners to secure the hood to the top of the windscreen frame I belive. My 2006 Roadster has a long U shaped steel channel with a U shaped rubber extrusion glued inside. This is attached to the front of the hood and it drops over the top of the screen frame and is secured by over-centre catches at either end. Much easier than ripping your fingernails off trying to get the hood on in January. I need to glue the rubber extrusion inside the steel U section channel.
Posts: 1,394 Likes: 257
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,394 Likes: 257 |
Ring Allon White's and ask what they use. They did mine in the past but I don't know what glue they used....🤷🏻♂️
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
It will be an industrial neoprene adhesive a stronger version of Evostick. Not all contact adhesive set straight off, they allow you to move the piece to the right location.
You should find some at a DIY store but the trick is to preclean & degrease all contact surfaces using say meths. The setting time is controlled b how fast the solvents flash off. Ensure you do it in a well ventilated area.
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Use Dunlop 1358 (brushable) or Alpha AN189 (Sprayable)
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Like I said earlier, you need a thixotropic contact adhesive - easy enough to come by.
Posts: 8,659 Likes: 407
Posts: 8,659 Likes: 407 |
Unfortunately the Alpha Thixofix is water based. Below is the adhesive Allon White use for the header rail seal. ![[Linked Image]](https://cdn.sotel.de/images/1000554098/weicon-gmk-2410-gummi-metall-kleber-16100350-350g-001.jpg)
Posts: 19 Likes: 1
Thanks to all for your advice. I've gone for the Weicon GMK 2410 option. £24 a tube! I love the smell of polychloroprene in the morning.
