3 members (JMcL, Camelot, Zach),
338
38
SORN
New
Topics48,367
Posts813,405
Members9,215
Posts: 756 Likes: 9
Posts: 756 Likes: 9 |
I reached the end of my clutch disc, it happened suddenly when downshifting the gear change was hard and tended to slip I turned around and 25 km to get home, my two old clutch discs with broken springs and 15,000 km on average so I had reassembled my first clutch disc which was still in good condition replaced for safety at the factory when replacing the chassis in 2015, it weakened after about 100,000 km,as these two discs with broken springs were disassembled while trying to repair them I found a 180 mm Alpine A110 disc for a ridiculously low cost so I decided to modify it to adapt Alpine 110 to adapt the correct gearbox shaft groove that I will have laser welded, then I replace the plastic centering rings with metal and remake all the closing rivets to rivet it again. A day's work plus 46 euros for a new clutch disc should not be worse than the original quality. https://ibb.co/Z1h3G8ghttps://ibb.co/161dXK5https://ibb.co/7VdzW9khttps://ibb.co/6vf1LC9
Posts: 756 Likes: 9
1 member likes this:
atalante83 |
Posts: 756 Likes: 9
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
Impressive work GLLOQ, as always. I suspect that the transmission of your M3W gets a lot more stress than most? You have a pretty top end engine as well I think? The transmission is fairly marginal for even a standard M3W, other than the reliable Mazda gearbox. As you make one part stronger and better the next weakest link in the transmission breaks. Leaving the Centa rollers as they are could be the best option? They are relatively easy and cheap to replace and may act as a limit or "fuse" to protect the other components?
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
Right Gilbert is one of the great riders in Mtw And the best mécanic doctor i know. Enormous job done
Will Stotts |
Posts: 703 Likes: 70
Posts: 703 Likes: 70 |
Bravo Taraud à vis Parker
Lille - North Of France
Sold : MTW 2012 / Mog 4-4 Sport 2010 / Mog Roadster V6 2008 Mog Super3 2024
Posts: 756 Likes: 9
I am very satisfied with the modified Sachs clutch disc, it works perfectly after 400 km, it seems more progressive than the original discs.
Posts: 756 Likes: 9
I would replace the friction linings of my 2013 disc with the linings of one of my discs with a broken spring. I think I have enough for a few decades. If Morgan sold the quality disc-mechanism assembly, I might have bought another one. I have already paid twice for poor quality second generation clutches with a statospheric price.
Posts: 756 Likes: 9
I just want to say that the clutch disc cores were TIG welded and not laser welded because it was not immediately available and I had another job to ask them to do at the same time.
