5 members (DPEvans, ScottMellor, James B W, Steve +8, CooperMan), 290 guests, and 65 robots.
+8Rich 97
Posts837,260
Page 3 of 5 1 2 3 4 5
Suggest having a word with Speedy Cables: they are the people responsible for the "Smiths" instruments used by Morgan - and very helpful in my experience.
Nick
linklaw Offline OP
Just sent them an email. Thanks for the suggestion.
John Linkosky
1995 4/4
2005 Roadster
2016 3W Superdry Edition
Originally Posted by linklaw
I checked the polarity of the purple wire with a test lamp. Wire to ground lights up the lamp so reverse polarity does not seem to be the problem. Will report back after further experimentation.
Don't wish to be critical, but just for sake of correctness: A test lamp between two terminals will always light regardless of polarity.
As Sewin suggested earlier, the only sure way is to use a multimeter or DC moving coil voltmeter, which will show a negative reading or the case of analoque instrument, the pointer will go in reverse.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Just my thoughts but, unless the battery was in the wrong way round so the whole car was reversed then lamping from a wire to the ground will show a +ve on the wire on lighting?
Yes indeed, agree as long as it’s a true ground i.e. visible chassis connection, and not just using the other wire assuming that’s the grounded one.
Doug
1958 Triton 650
Agreed ... just a bulb between the two wires would tell you nothing in terms of polarity as you say ... would have to be chassis ground
linklaw Offline OP
Point of clarification. I put the probe from the test lamp on the purple wire and with the clip on the other end of the test lamp I touched the under dash steel hoop. The light lit up, indicating the purple wire had power (positive). I then ran the probe from the black ground wire and touched the clip to the hoop and the light did not light up, indicating that the black wire is the ground (negative). If the purple wire did not light up and the black wire did light up, that would indicate that the battery was connected backwards. Of course, the two wires could be connected to the wrong poles on the clock. I didn't want to switch them for fear of burning out the clock.
John Linkosky
1995 4/4
2005 Roadster
John, others may have already advised you about this. Working under the dash with the battery connected is frankly asking for trouble. I've had my share of serious issues with car electrics over the past 50 years, including at least one (fibreglass) one catching fire. PLEASE get a professional car electrician to sort this for you.
linklaw Offline OP
I pulled the clock out of the dash and it had a manufacturer's name and part number on it. I contacted the manufacturer, Caerbont Automotive, and ordered a new clock this morning. Now I can experiment on the old clock to see if I can make it turn around. Will report results, if any.
John Linkosky
1995 4/4
2005 Roadster
Caerbont is the company that manufactures classic Smiths branded gauges.
