1 members (OZ 4/4),
301
42
Topics48,341
Posts812,991
Posts: 77 Likes: 11
Posts: 77 Likes: 11 |
Hello
Is the Morgan factory use the metric system like in Europe? Thank you
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
My Plus Four 2023 model has a mix. The thread for the luggage rack bolt is not metric. I think it is UNF as I used a tap to clean it up. No idea what else uses metric/ imperial yet No doubt I'll discover that when the time comes!
Posts: 31 Likes: 4
Posts: 31 Likes: 4 |
Very unspecific question, certainly depends on the age of car & part
Posts: 1,576 Likes: 103
Posts: 1,576 Likes: 103 |
Depends .....
Since the 1930's Morgans have used a mix of Whitworth, Imperial and metric....
Arwyn
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Plus whatever else prevous owners have fitted
1 member likes this:
Graham, G4FUJ |
Posts: 7,894 Likes: 241
Posts: 7,894 Likes: 241 |
Plus whatever else prevous owners have fitted  Or incorrectly forced in
Posts: 71 Likes: 1
Posts: 71 Likes: 1 |
I'm pretty sure there was some British Standard Pipe Thread on my oil pressure take off.
On my previous, a 2002 Plus8, whenever I did a job I considered renewing fasteners. One example was removing the seats. The rear bolts on the runners were standard hex head. This head sat inside a channel so no room for a spanner or socket. Rather than wedge a screwdriver to lock it I used a small stilson type tool that fitted and held in with tape while undoing the nut. I replaced the bolts with socket heads and used a matched socket instead of a spanner/ hex socket/stilson.The front bolts left as they were as they had easy access. To help try and ID threads I have a thread gauge and a stock of nuts as testers, kept in small labelled plastic bags. Spanner size? I have sets of metric/imperial/whitworth etc plus some odds and sods rescued from scrap for modifying for specific jobs.
Posts: 7,921 Likes: 216
Posts: 7,921 Likes: 216 |
Having rebuilt my series Land Rover over the years I have a bin for imperial stainless (mainly UNF) plus one for metric fittings and a third for washers of various types. The former nicely covers most of the body/chassis/suspension fittings on my Roadster. I keep each bin topped up as I run out of any particular nut, popular length bolt or washer so I can be assured when needed the correct ones are there. For the most part except in critical load situations old fittings get replaced with stainless after dismantling as I hate to see rusty ones.
Posts: 35,776 Likes: 468
Posts: 35,776 Likes: 468 |
I've found over the 21 years of Morganing my set of BA nut spinners and and open enders come in handy too for the smaller stuff..
A good selection of Metric, Whitworth normally suffices.
An angle grinder for the exhaust has been known to be used in extremis on the U clamps..
