1 members (Morgan Dude), 289 guests, and 37 robots.
John V6 79
+8Rich 70
DaveW 68
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,936
Members9,203
PPP356
#818263 26/02/25 03:44 PM
S2K03 Offline OP
Hello
Is the Morgan factory use the metric system like in Europe?
Thank you
S2K03 #818273 26/02/25 04:40 PM
My Plus Four 2023 model has a mix. The thread for the luggage rack bolt is not metric. I think it is UNF as I used a tap to clean it up. No idea what else uses metric/ imperial yet No doubt I'll discover that when the time comes!
S2K03 #818276 26/02/25 04:55 PM
Very unspecific question, certainly depends on the age of car & part
S2K03 #818278 26/02/25 04:56 PM
Depends .....
Since the 1930's Morgans have used a mix of Whitworth, Imperial and metric....
Arwyn
S2K03 #818282 26/02/25 05:29 PM
Plus whatever else prevous owners have fitted laugh2
2025 MG ZS EV aka Trigger
John V6 #818295 26/02/25 08:06 PM
Or incorrectly forced in
S2K03 #818301 26/02/25 08:51 PM
I'm pretty sure there was some British Standard Pipe Thread on my oil pressure take off.
S2K03 #818320 27/02/25 09:54 AM
On my previous, a 2002 Plus8, whenever I did a job I considered renewing fasteners. One example was removing the seats. The rear bolts on the runners were standard hex head. This head sat inside a channel so no room for a spanner or socket. Rather than wedge a screwdriver to lock it I used a small stilson type tool that fitted and held in with tape while undoing the nut. I replaced the bolts with socket heads and used a matched socket instead of a spanner/ hex socket/stilson.The front bolts left as they were as they had easy access.
To help try and ID threads I have a thread gauge and a stock of nuts as testers, kept in small labelled plastic bags. Spanner size? I have sets of metric/imperial/whitworth etc plus some odds and sods rescued from scrap for modifying for specific jobs.
S2K03 #818323 27/02/25 10:30 AM
Having rebuilt my series Land Rover over the years I have a bin for imperial stainless (mainly UNF) plus one for metric fittings and a third for washers of various types. The former nicely covers most of the body/chassis/suspension fittings on my Roadster. I keep each bin topped up as I run out of any particular nut, popular length bolt or washer so I can be assured when needed the correct ones are there. For the most part except in critical load situations old fittings get replaced with stainless after dismantling as I hate to see rusty ones.
S2K03 #818324 27/02/25 10:48 AM
I've found over the 21 years of Morganing my set of BA nut spinners and and open enders come in handy too for the smaller stuff..
A good selection of Metric, Whitworth normally suffices.
An angle grinder for the exhaust has been known to be used in extremis on the U clamps..
2009 4/4 Henrietta
1993 Connaught Green +8 prev
