5 members (ch44, Morganmike, TalkMorgan, Soleng, gaston), 253 guests, and 49 robots.
+8Rich 95
Posts837,265
#818327 27/02/25 11:07 AM
2008 +4 has developed wood squeakes from an area to the right of the dash board. Around the area where the door and bulkhead meet, any ideas?
Adepooler #818328 27/02/25 11:19 AM
First check the bulkhead tape. Some were tacked into place and if a tack loosens it will creak in the frame. How do I know this? Also lubricate the tape with either Vaseline or Beeswax.
Adepooler #818368 27/02/25 08:09 PM
I rub the bonnet tapes with an old candle, less messy than Vaseline - mind you if we have a power cut...
Adepooler #818369 27/02/25 08:14 PM
Try lip salve in their neat little cylindrical dispensers.
Adepooler #818378 27/02/25 11:24 PM
1. Maybe try a run of 3 in 1 oil on the beading along full length of running board.
2. I once had a squeak which was the top of the steering cowl touching the under side of the dash. Just backing off the adjustable steering column by half a mm cured it.
3. Rather than grease bonnet tapes, which then makes a mess on your polishing cloths, I line the inside of the bonnet edge with the furry side of sticky back velcro tapes.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Adepooler #818384 28/02/25 10:58 AM
I like to keep my bonnet tape material clean too, anything applied that makes it wet or sticky attracts dirt and grit and wears the bonnet paint. I used to use candle wax, only takes a small rub on each section but now i line the inside surface of the bonnet front and rear with PTFE tape, works really well and everything is dry and clean!
