0 members (),
330
53
Posts837,276
Posts: 14 |
2008 +4 has developed wood squeakes from an area to the right of the dash board. Around the area where the door and bulkhead meet, any ideas?
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
First check the bulkhead tape. Some were tacked into place and if a tack loosens it will creak in the frame. How do I know this? Also lubricate the tape with either Vaseline or Beeswax.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I rub the bonnet tapes with an old candle, less messy than Vaseline - mind you if we have a power cut...
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
Try lip salve in their neat little cylindrical dispensers.
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
1. Maybe try a run of 3 in 1 oil on the beading along full length of running board. 2. I once had a squeak which was the top of the steering cowl touching the under side of the dash. Just backing off the adjustable steering column by half a mm cured it. 3. Rather than grease bonnet tapes, which then makes a mess on your polishing cloths, I line the inside of the bonnet edge with the furry side of sticky back velcro tapes.
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
I like to keep my bonnet tape material clean too, anything applied that makes it wet or sticky attracts dirt and grit and wears the bonnet paint. I used to use candle wax, only takes a small rub on each section but now i line the inside surface of the bonnet front and rear with PTFE tape, works really well and everything is dry and clean!
