0 members (), 240 guests, and 40 robots.
John V6 78
+8Rich 71
DaveW 67
Luddite 57
9,203 Registered Users
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,335
Posts812,897
Members9,203
kamo30
rcmatt #819101 10/03/25 11:10 PM
rcmatt Offline OP
actuallyat start up it spits some our at the exhaust and I get a fair amount of burnt oil smole. When I drove it last fall on the Maggie valley ride the person behind me could smell the burnt oil. It especially was bad when using compression (which is actually vacum) going down hill
Rodger
2004 Plus 8 (wife's)
rcmatt #819105 11/03/25 12:17 AM
Has the crankcase ventilation system ever been disassembled? In the breather pipe from the crankcase to the intake manifold there is a small insert that keeps excess manifold vacuum flow from sucking oil into the intake. Leave that out and your engine will be 'breathing' oil vapor. If you remove the air filter and take a look down the intake tracts they should be clean. Any oil residue is indication of an issue.
Late 2012 M3W
rcmatt #819406 13/03/25 04:03 PM
rcmatt Offline OP
That system has never been dissassembled. But it does make me wonder if there is excessive pressure in the oil system. Correct me it I am wrong, but shouldn't the lid to the oil tank vent? After I changed the timing belt (I need to write up a tutorial on that so others do not make all the mistakes I made) I ran the engine with the cap off the tank. There was no oil burning smell from the exhaust
Rodger
rcmatt #819469 13/03/25 09:48 PM
The oil tank cap doesn't vent, by design. And lest you be tempted to go down the path of re-designing the breather system as some have done at great expense you should understand the factory system is fine, as long as it's working correctly.
If you haven't yet relocated the vent line from the tank to the cam case (the smaller line, RF of engine), it's worth doing as many cars have that line routed with a low dip just to the rear of the engine that can allow congealed oil foam to block that line. Frequent short drives that do not heat the oil enough to evaporate the inevitable water in the oil can create that oil/moisture foam (looks like frothed mayonnaise) and if not allowed to fully drain back into the cam case when things are hot, can lead to a blockage in the 'dip' when things cool down.
You also want to ensure the short hose from the top of the cam case to the inlet manifold is not blocked, and that the small orifice piece is in place. Also, there is a thin stainless reed valve in the cam case that needs to be functioning, and though rare, I have read of a couple of breakages.
But have you removed the air cleaner assembly to inspect the intake tracts yet? That will tell you if the engine is ingesting oil there. If not, then it's coming in through the guides or past the rings.
Late 2012 M3W
1 member likes this: planenut
