0 members (), 293 guests, and 34 robots.
+8Rich 93
Posts837,277
Page 4 of 5 1 2 3 4 5
linklaw Offline OP
Received my new clock yesterday. It looks exactly like the old clock. I haven't installed or connected it yet. Will report once I do.
John Linkosky
1995 4/4
2005 Roadster
2016 3W Superdry Edition
A 2005 Morgan has certainly an electronic Quartz clock and wrong polarity will either fry the unit or it won't work at all. Internally is a "stepper", a magnet coil that advances the gears. I assume there is sticking oil/dirt on the gears that causes it to reverse ! Or maybe its one of those joke clocks that go reverse cheers
linklaw Offline OP
I installed and connected the new clock over the weekend. Happy to report it is keeping the correct time and moving in the right direction.
John Linkosky
1995 4/4
2005 Roadster
Good news John, you may care to offer the old one to Gary (OZ 4/4) on here as he runs a DeLorean out there....
Ah, but during the flight over won't it reverse direction as it's nearer the south pole magnetism ? grin2
An “impulse” buy gone South there then 😎
Richard, your mention of impulse relative to time... I have an old Synchronome master clock up in the attic, of the type that kept accurate time time in many public buildings of all sorts such as schools airports government offices and much more....Interesting times... (-:
George would that be the same as the old clocking in one's where you stamped your works card in going back to one of my first jobs.
Sort of mini grandfather clock with a lever near where you inserted your card that you pushed down to stamp your card for the wages office, a lovely unit.
1 member likes this: +8Rich
Good find Jon G. Thanks for posting.
The master clock was a master to slave clocks which were simple ratchet and pawl devices which were wired in series with each other and reacted to an electrical impulse supplied by the master every 30 seconds, thus the minute hand could be seen to jump forward every half minute and on every slave in the system. Many tower and ornamental clocks attached to the exterior of significant high street shops were slaves to a Synchronome master .
There were other time related devices such as you suggest Richard operating on the same principal to record employees attendance times which were either stand alone or attached to a master clock to ring school bells, sound factory tea breaks, etc.etc.etc... Enough already... (-:
