New
Topics48,365
Posts813,345
Members9,215
Posts: 13 |
I’ve just got a S1 Roadster and I’m wondering if anyone has recommendations for a high level brake light that can be attached to a case on the rack.
Many thanks
Marcus
Ural 750 Combination with a Border Terrier, and a 3ltr Roadster
Posts: 35,791 Likes: 471
Posts: 35,791 Likes: 471 |
Posts: 13 |
Thanks lots of interesting options. I was wondering if there was a solution that I could Velcro to a Peli case?
Worth getting one of these and see how it works for you.
1 member likes this:
OZ 4/4 |
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
Plenty on ebay etc. I added a Y piece with two connectors so the cobra light stayed avtive but I could add one to the luggage. Then on arrival on holiday if the case was off the car the cobra could be used.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
I have a Cobra high level ligh5 on my car. A suitcase obscures it so I bought a light to strap to the caee. Simple enough mods to the cables using waterproof connectors. Simple swop plugs to eithe4 have the Cobra or extra light in circuit. I think I got my light from Carbuildersolutions and the connectors from Halfords ( Superseal brandcI think). Cheap and effective.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Yellow is the best visibilty for visuals apparently, and why railways in the UK use it.
But a yellow Morgan is invisible whether the lights are on or not.
I once followed a black 4/4 on the M42 in the dark in heavy rain. He also had black and silver number plates. He was almost invisible amongst the SUVs with huge tail lights.
Posts: 7,942 Likes: 218
Posts: 7,942 Likes: 218 |
My high level luggage light uses similar LED strip mounted on wooden batton that is secured under luggage straps. ![[Linked Image]](https://i.imgur.com/1Mcnb8K.jpg) It was a no brainer to fit an OE Econoseal plug to lead, identical to one powering cobra light, allowing swap to power the batton instead.
Posts: 170 Likes: 5
Posts: 170 Likes: 5 |
Mine is very similar to Richards except I use velcro to attach the LED strip to my suitcase and I glued a connector for it, next to the Cobra base, so I didn't have to fish around the side of the spare wheel to connect it.
Mark
Mark 2015 +4 Ferrari Le Mans Blue
Mine is a similar style too. Mounted on a strip of oiled hardwood with loops to run a strap through. A basic 25mm cheap ratchet style strap that goes round the case under the leather straps. This strap also stops sideways movement of the case.
