1 members (Saxonian),
161
88
Topics49,847
Posts837,389
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
Thanks for all the links and tips. I was wondering how to do this and it doesn’t seem so bad after all. It might even be easier having those male fasteners in place.
Roger 2011 Plus 4
Posts: 1,046 Likes: 148
Posts: 1,046 Likes: 148 |
Mine's an unused mohair with no fasteners so need to fit those. I have the fasteners on the car though. As explained, I was missing the male studs so it sounds like you've got the opposite job to me Rog. Thanks for all the links and tips. I was wondering how to do this and it doesn’t seem so bad after all. It might even be easier having those male fasteners in place. The Trimming Shop seems to offer all the punch and die sets for adding female press studs to fabric, perhaps apply a little Tipex on your male studs and while it's still wet press the mohair onto it to mark where to punch the fabric, the Tipex will be easy to remove later once dry. Keep in mind mohair has the tendency to shrink over time, after it's seen some rain and gone through a few natural drying cycles you'll be surprised how much shrinkage you get with mohair, with this in mind I'd be inclined to make the first fit a bit baggy to allow for this inevitable shrinkage. Let me know how adding the two extra zips goes? Dave.
Thanks Dave. Yes I have the opposite. My car came with a bright red tonneau. It was always a bit loud against the darker red leather so let it go. This black one without the fittings should work nicely on the black car.
Thanks for pointing out the mohair shrinkage. Hadn’t thought of that. I think I will drench/dry a few times before attempting the fit. Will let you know how the zip fitting goes…
Roger 2011 Plus 4
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Our shoulder belts don't have retractors but here's what I had done. I got the zippers and a friend who has a heavy duty commercial sewing machine did the work. ![[Linked Image]](https://tm-img.com/images/2025/03/23/IMG_7866.md.jpg)
1 member likes this:
MOGDave |
Slightly different belt path to my 2012 Plus 4, but that looks neat
I wonder if my trimmer could add two curved (J shaped) zip runs as shown in white? ![[Linked Image]](https://i.ibb.co/1Gf2pcJ4/IMG-20250409-WA0000.jpg) When unzipped the redundant flap of tonneau material could then be folded down the red line to sit out of the way against the door card
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I wonder if my trimmer could add two curved (J shaped) zip runs as shown in white? ![[Linked Image]](https://i.ibb.co/1Gf2pcJ4/IMG-20250409-WA0000.jpg) When unzipped the redundant flap of tonneau material could then be folded down the red line to sit out of the way against the door card  How would you get out when bursting for a wee? Am I just showing my age?
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
I wonder if my trimmer could add two curved (J shaped) zip runs as shown in white? ![[Linked Image]](https://i.ibb.co/1Gf2pcJ4/IMG-20250409-WA0000.jpg) When unzipped the redundant flap of tonneau material could then be folded down the red line to sit out of the way against the door card  Seems a bit of overkill to me. Why not do it like I did, but with a zipper 2-3" longer? That would clear the belt retractor.
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
I got made an additional zipper, parallel to the center one and just as long. It is placed a little more medial than your red stripe, so you can still use the most lateral stud on the scuttle. In that way you can even drive with the vertical part of the tonneau fixed, for a little more protection. No problem putting it on and taking it off from inside the car, or you can just tuck it away, it will not foul the belt. Now the horizontal flap is rolled backwards and the roll fixed with two straps added to the tonneau behind the head rests, using press buttons, much like a "door" or window on a camping tent, or the sidescreen on a boat canvas top if you like. In that way the redundant cloth of the tonneau stays in a roll outside, rather than folded up inside. In this way the tonneau doesn´t even touch the belt.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
No need for zips if the tonneau is properly folded. There’s an explanation here.
Ken
