6 members (sezznowt, RichardV6, teknome, Biggle, Cerberas, PaulV), 252 guests, and 64 robots.
+8Rich 75
Topics49,861
Posts837,534
Jonny72
#821740 16/04/25 11:11 AM
PaulJ Offline OP
Another question if I may?
My new car has a 'cleaned up' front end and consequently no spotlights, and, whilst the LED mains are perfectly good, I could do with some light shining way down the road where the current beam ends.
Does anyone have suggestions for a pair of good, powerful, spots. Recommendation is always best as I don't want to buy some and then find they are not as good as I wanted.
Thanks.
PaulJ #821741 16/04/25 11:29 AM
Online NoMood
Beware that LED spotlight's pointing higher than the 8 inch headlamps on main beam will blind you on sign reflections. Having said that it might be worth checking headlamp adjustment on main and dip beam as from your comments they may be a little low on the former.
PaulJ #821757 16/04/25 04:19 PM
PaulJ Offline OP
That point about blinding oneself is very valid Richard, it happens with the LED headlights too. The lights are actually about right, any higher and the dip cut off would be too high, and in fairness the range is good, I just need it to be better, especially down here in the South West, where there is a lot of wildlife on the roads. I have had 2 deer strikes, a Badger strike and a Hawk who was feasting on some road kill as I rounded a bend, and flew away up, right into my nearside headlamp, taking the lens, reflector and indicator with it. That was expensive on a nearly new M3!
1 member likes this: RichardV6
PaulJ #821998 19/04/25 03:36 PM
PaulJ Offline OP
If anyone actually has a pair of good LED spot lights they want to sell, I might well be interested in buying them. Just PM me please.
PaulJ #822013 19/04/25 11:05 PM
Would it be OK to fit older spotlights and swap the bulbs for LED's?
I know its illegal to do this with headlamps but not sure of the legality with spots.
Mark
2015 +4 Ferrari Le Mans Blue
PaulJ #822016 20/04/25 06:19 AM
Online NoMood
I know the ARP4 had dedicated LED headlamps and LED auxiliary lights. Not sure if spots or fog though.
PaulJ #822264 22/04/25 08:25 PM
Thanks.
Paul, I had heard of an early CX adopter who tried to fit extra spotlights using the proper harness points installed and taped back, only to end up with an epic fail - in the end the car had to go to the Factory service dept to have the BCU flashed to energise the relevant circuit and tell the car it had spots fitted (& it was a chargeable update)
So may be worth checking with your local friendly dealer before committing the hard earned ££
PaulJ #822294 23/04/25 10:02 AM
Paul,
sorry to ask, what type and model year is your new car?
Clemens
PlusFour Red Baron MY 2022
PaulJ #823089 06/05/25 06:51 PM
PaulJ Offline OP
Thanks for the heads up Jon, and Clemens, it is an Oct. '24 registererd, MY '25 car - if that make sense?
