2 members (JoeSpeetjens, Bitsobrits), 253 guests, and 103 robots.
Topics49,847
Posts837,389
Picture from Gorch
Clemens
PlusFour Red Baron MY 2022
riri Offline OP
könnt ihr mir helfen was der runde zylindrische körper auf dem fuss kasten ist?
lg riri
Greatings from germany, +8 1997 3,9 l blue
Das ist die carbon filter. Sorry my Germany can't do this,, it is a filter to store petrol VOCs from the tank space & then release them at high revs . It is not the pump.
riri Offline OP
thank you john for the digramm. i search more and other diagramms on these side but i don´t find something else. you have a link?
Lieder Ich habe nichs meer
riri Offline OP
wie bekommt man diesen carbonfilter geöffnet? ist im inneren ein filterstoff zum austauschen?
X
X
Den Carbonfilter kann man meines Wissens nicht öffnen. Der ist bei allen Autos dieser Zeit üblich.
Die Benzinpumpe sitzt vermutlich unter der Ablage, wie beschrieben. Die haben normal die Größe etwa einer Zündspule.
Etwa 5-7cm Durchmesser, ca. 12-15cm lang.
You couldn‘t open the carbonfilter. It‘s a part fitted in all cars of this time.
The fuelpump you‘ll find under the parcelshelf behind the seats. It‘s about the size of an ignitioncoil.
Approx. 2-3“ diameter and 4-5“ long.
Greets René
2018 plus4 (sports green)
riri Offline OP
wozu ist der carbonfilter gedacht?
Here is the answer from ChatGPT
In older vehicles, a carbon filter (also known as an activated carbon filter) is mainly used in the tank ventilation system. Its task is to trap gasoline vapors that form in the fuel tank, especially when there is heat or movement.
Purpose and function:
Prevention of emissions: The carbon filter prevents volatile hydrocarbons (gasoline vapors) from escaping directly into the atmosphere. These vapors are harmful to the environment and contribute to the formation of ground-level ozone.
Intermediate storage of the vapors: The activated carbon in the filter binds the petrol vapors.
Recirculation into the engine: When the engine is running, the stored vapors are fed back into the intake tract via a valve (purge valve), where they are also combusted.
Even in older vehicles without modern OBD systems, this filter was part of the exhaust gas aftertreatment (in particular to reduce evaporative emissions), often as early as the 1980s.
In principle, the activated carbon filter is maintenance-free and designed for a long service life - often the entire life of the car.
Hier die Antwort von ChatGPT
Bei älteren Fahrzeugen wird ein Carbonfilter (auch Aktivkohlefilter genannt) hauptsächlich im Tankentlüftungssystem verwendet. Seine Aufgabe ist es, Benzindämpfe aufzufangen, die sich im Kraftstofftank bilden, besonders bei Wärme oder Bewegung.
Zweck und Funktion:
Vermeidung von Emissionen: Der Carbonfilter verhindert, dass die flüchtigen Kohlenwasserstoffe (Benzindämpfe) direkt in die Atmosphäre entweichen. Diese Dämpfe sind umweltschädlich und tragen zur Bildung von bodennahem Ozon bei.
Zwischenspeicherung der Dämpfe: Die Aktivkohle im Filter bindet die Benzindämpfe.
Rückführung in den Motor: Beim Betrieb des Motors werden die gespeicherten Dämpfe über ein Ventil (Purge Valve) wieder in den Ansaugtrakt geleitet und dort mitverbrannt.
Auch bei älteren Fahrzeugen ohne moderne OBD-Systeme war dieser Filter Teil der Abgasnachbehandlung (insbesondere zur Reduktion der Verdunstungsemissionen), oft bereits ab den 1980er Jahren.
Grundsätzlich ist der Aktivkohlefilter wartungsfrei und auf eine lange Lebensdauer ausgelegt – oft das ganze Autoleben lang.
Clemens
1 member likes this: xc68anc
