6 members (jbk, DickJ, Rovert, Mkiss, mph, The Flitting), 312 guests, and 51 robots.
John V6 68
+8Rich 65
DaveW 64
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,063
Captain Morgan, IRWIN
Max5 Offline OP
Has anyone found a lasting solution to the long travel brake pedal and the associated "mushy" brakes on MY22 Plus Fours?
Mine is fine. I know KH tilt the car whilst bleeding to help get all air out
2025 MG ZS EV aka Trigger
I believe John is correct, the secret for the pedal is to get all the air out ( as always ). On our 2020 Plus Six the ABS acuator block is located under the near side wing, near the windscreen washer bottle and the swirl pot. The actuator blocks on some cars and bikes can sometimes be tricky to purge of air.. I have a hand held vacuum pump designed to pull the fluid and air through the system from the bleed point, works far better than the standard up/down of the foot pedal method. Just have to make sure someone is at the master cylinder topping up the reservoir, because it sure pulls the fluid though quickly.
Dave
Plus Six "Squeak"
Roadster departed.
The best method I have found is to use a combination of a positive pressure bleeder and pumping the pedal. I have a Sealey bleeder and it's got a ginormous tank on it so no worry about running the Master cylinder down. Pressurise it up to its operating pressure and then open each nipple in turn whilst my glamorous assistant pumps the pedal in a series of rapid moves. The reason this works well is that often you can get small bubble caught in odd nooks and crannies which a constant pressure won't shift as the flow rate is still low. Add the pumping though and the additional jerk will tend to move things along nicely.
I learned this some years ago when I first got the bleeder. On my first attempt I must have put 2 litres of fluid through the system but still some annoying sponginess. I went to ask my friendly local garage for advice and they put me on to the combination method. Works brilliantly and you can bleed out an entire system in a few minutes. It does depend on having a glamorous assistant to hand though. Fortunately mine is easily bribed with promises of chocolate.
2 members like this: Graham, G4FUJ, Davetherave
The MY22 CX has two wonderful upside down U bends above the cylinder to trap air. Another feature
Chocolate is always a good move! grin2
'09 Gen2 MINI Cooper ragtop
Plus those awkward banjos, with blind drillings and abrupt changes of direction to trap micro bubbles
For an unknow reason the braking is very good just after washing the car. But after two or three braking it is again soft. I am even able to activate the abs wich never happens when a drive the car.
Probably rust on brake discs.
1 member likes this: Hamwich
Justement je fais un petit tour après le lavage pour éviter la rouille.
Et la pédale n'est pas du tout molle et ne s enfonce pas.
