7 members (Sir Percival, GrumpyPa, Brian G, Mogguy2, howard, Themorganeer, DJC),
264
34
Topics48,343
Posts813,025
Posts: 193 Likes: 29
Posts: 193 Likes: 29 |
However, cannot convince myself how they can conclude that it is an “isolated incident” without at least examining a representative sample of other cars. Absolutely spot on.
MY2023 Plus Six "Rachel" MY2022 Volvo C40
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
The rack is held in place bye two m14 bolt's apparently they had loosened over time one had dropped out and the other was kept together with a a few threads left .As mentioned before it had never happened before so cant tell you anymore. Is there spare thread to add a locking nut? I'm guessing not
Posts: 11,861 Likes: 137
Posts: 11,861 Likes: 137 |
If MMC have never seen it before then my guess would be that in production the bolts are supposed to be secured with Loctite and for some reason it didn't get applied in this case?
In any circumstance, safety-critical fasteners should always have some sort of security be it lock nuts, tab washers, lock wire, or a bonding agent used.
Posts: 7,342 Likes: 91
Posts: 7,342 Likes: 91 |
The fact that two M14 screws came loose is probably the correct explanation for the cause. However, as long as there is no communication about how these M14 screws are (normally) secured during production, one can almost fear that they are not secured at all. This would be a time bomb for the entire series. MMC should therefore make every effort to quickly communicate publicly how these two screws are secured and that, for whatever reason, this may have been overlooked in individual cases.
Posts: 1,011 Likes: 243
Posts: 1,011 Likes: 243 |
First of all, I'm very pleased that MMC has accommodated a customer to the extent that he is satisfied. What I still need information on is how CX owners can check whether their morgan is experiencing the same problem as aerotaff's.
Clemens
PlusFour Red Baron MY 2022
In the first instance, If you can jack the front of the car up, remove the wheels and look for any play in the steering arms. Any local garage would be able to do this if you don't have the necessary equipment at home.
For a more detailed check you would need to remove the relevant cover plates to get access to the steering rack itself in order to check the mounting bolts.
I have put that on my annua lcheck for the local garage Tim.
Posts: 2,383 Likes: 56
Posts: 2,383 Likes: 56 |
Tim. Good advice the wheels have been off three times in my ownership for a clean check and fettle the suspension bolts etc were all checked it went through two Mot's every time the play was checked. What nobody does is take the plate off and why should you I think many people will from now on . Em
Posts: 909 Likes: 7
Posts: 909 Likes: 7 |
Which of the two plates has to be removed to get to the M14 screws? The one on the side or the one from the underbody? Has anyone done this before?
Clemens
