Topics49,841
Posts837,327
Posts: 98 Likes: 2
Posts: 98 Likes: 2 |
May I ask for some advice regarding polishing chrome wire wheels. There are numerous rust spots and blobs on the outer rims and significantly more on the inner rims. What is the most effective way to remove this rust? Thanks Gary
Posts: 8,660 Likes: 408
Posts: 8,660 Likes: 408 |
You could try tinfoil Gary. Crumple some up then using water maybe with a little detegent rub away. It should remove rust without scratching the much harder chrome. When happy with finish you will need to protect with metal sealant.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Rub down with scrunched up aluminium baking foil dipped in coca cola.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I use Autosol with a cloth, a good coating of proper wax polish after or you could try Rimwax.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 98 Likes: 2
Thanks for the advice above.
I wish I had taken before and after photos......the difference is quite remarkable. I found using Autosol after the foil and coke combination resulted in a super finish.
Many thanks again
1 member likes this:
Deejay |
