0 members (), 215 guests, and 38 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,335
Christoph
May I ask for some advice regarding polishing chrome wire wheels.
There are numerous rust spots and blobs on the outer rims and
significantly more on the inner rims.
What is the most effective way to remove this rust?
Thanks
Gary
You could try tinfoil Gary. Crumple some up then using water maybe with a little detegent rub away. It should remove rust without scratching the much harder chrome. When happy with finish you will need to protect with metal sealant.
Rub down with scrunched up aluminium baking foil dipped in coca cola.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I use Autosol with a cloth, a good coating of proper wax polish after or you could try Rimwax.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Thanks for the advice above.
I wish I had taken before and after photos......the difference is quite remarkable.
I found using Autosol after the foil and coke combination resulted in a super finish.
Many thanks again
1 member likes this: Deejay
