10 members (RichardV6, Grumpy2, Moggo, Oskar, richardUK, MDS61, BobtheTrain, +8Rich, Graham, G4FUJ, DCH), 300 guests, and 43 robots.
John V6 79
+8Rich 69
DaveW 67
Luddite 57
9,203 Registered Users
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,336
Posts812,906
Members9,203
toitoine
#825635 19/06/25 01:19 PM
It took 37 Years!
It took 37 Years!
Having been laid up myself for just over three weeks, but now feeling a little more mobile, I decided this morning to fire up my 4/4 only to find the battery was too flat to turnover the engine. There’s a socket fitted to allow easy charging so half an hour on charge provided enough amps to get the car started, but I wondered whether that much battery drain in less than a month is normal, or is my battery on the way out.
Grateful for any thoughts, please
Mark
Mark Turner #825638 19/06/25 01:49 PM
How old is the battery?
1854sailor #825641 19/06/25 02:39 PM
It took 37 Years!
It took 37 Years!
No idea - only got the car (1999 4/4 4 seater) a couple of months ago.
Mark Turner #825642 19/06/25 02:49 PM
Believe it or not the clock and flashing immobiliser light was enough to drain the battery!
Better since i swopped the starter for a hi torque one .
Mark Turner #825643 19/06/25 02:56 PM
What's the voltage reading from the battery? Anything less than 12.6V and the battery probably needs replacing.
Mark Turner #825649 19/06/25 04:41 PM
Online NoMood
Unfortunately the standing voltage battery test only tells you the state of charge of the remaining capacity Tim, so could be the same on a new as well as a 10 year old battery if the latter had recently been used. Typically much reduced capacity is only realised after a layup or the first hint of winter temperatures and often masked by leaving battery on a conditioner/charger.
1 member likes this: Hamwich
Mark Turner #825651 19/06/25 04:55 PM
There should be a code or date stamp on the top of the battery, also knowing the brand is helpful as not all brands are equal quality
brownbaker #825656 19/06/25 05:19 PM
It took 37 Years!
It took 37 Years!
That’s all that should have been drawing down on my battery. When I can bend down to have a look at the battery I’ll probably take the opportunity to replace it.
Mark Turner #825676 20/06/25 02:27 AM
You could also install a battery disconnect switch.
1 member likes this: +8Rich
1854sailor #825678 20/06/25 03:45 AM
There are sound reasons why these were factory fitted, before the accountants got involved I suspect, I shall fit one to our Son's 4/4 Sport before he picks it up so he won't need a charger float at all.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
