3 members (Chris Cosher, JohnHarris, Montegue), 295 guests, and 33 robots.
+8Rich 92
Posts837,277
#826122 27/06/25 09:20 AM
i gave the car a good clean and wash this morning and good practice i always give the top of the engine a dry from water getting in under the louvres.Today I lifted the sponge filter to give it a clean and noticed the water drain from the box was directly on top of a large choc box connector with blue and red wires which was full of water. Now sprayed cleaned and taped I bet yours are exactly the same.
That doesn't sound like a standard MMC connector or location. Did the factory or dealer fit an optional extra in that area I'm wondering thinking
Factory fit Richard on early 2020 plus6.
I checked my 2022 Plus Four. There is no connector but it does look possible to add a drain pipe to the outlet to divert water further away. The drain is just above the white label and below the other pipe that crosses the photo
Sorry cant do pictures, it comes out of that loom just under the hole deffinately factory.
Have sent you a PM (see enevlope top right on the page) . If you email me the picture I'll post it
Nothing below mine Em.
Mike
1982 4/4
1999 +4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
Morgan never managed water issues properly, whether there's a box under a drain or not. The laterTrads have drains emerging from the heater box, which are improved by adding a length of clear tubing. Its such a simple inexpensive add-on that it makes no sense not to have done it in build.
Ignoring the fact that louvres will soak the engine in wet weather never made sense, when a simple cover would fix it. Thats the Morgan way.
If any duratec trad owners are looking at this.Pull your plugs out you might have a bit of a shock....Em
There you go EM.
Mike
1982 4/4
1999 +4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
