Topics48,346
Posts813,049
Posts: 2,383 Likes: 56
Posts: 2,383 Likes: 56 |
i gave the car a good clean and wash this morning and good practice i always give the top of the engine a dry from water getting in under the louvres.Today I lifted the sponge filter to give it a clean and noticed the water drain from the box was directly on top of a large choc box connector with blue and red wires which was full of water. Now sprayed cleaned and taped I bet yours are exactly the same.
Posts: 7,923 Likes: 217
Posts: 7,923 Likes: 217 |
That doesn't sound like a standard MMC connector or location. Did the factory or dealer fit an optional extra in that area I'm wondering
Factory fit Richard on early 2020 plus6.
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
I checked my 2022 Plus Four. There is no connector but it does look possible to add a drain pipe to the outlet to divert water further away. The drain is just above the white label and below the other pipe that crosses the photo ![[Linked Image]](https://tm-img.com/images/2025/06/27/1000042742.jpg)
Sorry cant do pictures, it comes out of that loom just under the hole deffinately factory.
Have sent you a PM (see enevlope top right on the page) . If you email me the picture I'll post it
Posts: 87 Likes: 1
Posts: 87 Likes: 1 |
Nothing below mine Em. ![[Linked Image]](https://tm-img.com/images/2025/06/27/IMG_4001.jpeg)
Mike 1982 4/4 1999 +4 2004 Roadster S1 2010 Roadster S2 2021 Plus 6
Posts: 21,868 Likes: 167
Posts: 21,868 Likes: 167 |
Morgan never managed water issues properly, whether there's a box under a drain or not. The laterTrads have drains emerging from the heater box, which are improved by adding a length of clear tubing. Its such a simple inexpensive add-on that it makes no sense not to have done it in build.
Ignoring the fact that louvres will soak the engine in wet weather never made sense, when a simple cover would fix it. Thats the Morgan way.
If any duratec trad owners are looking at this.Pull your plugs out you might have a bit of a shock....Em
Posts: 87 Likes: 1
There you go EM. ![[Linked Image]](https://www.tm-img.com/images/2025/06/27/PHOTO-2025-06-27-16-18-44.jpg)
