0 members (),
336
Posts837,277
Posts: 564 Likes: 79
Posts: 564 Likes: 79 |
Hi Em, i had a look at our 2020 Plus Six and we do not have the wiring connector under the drain outlet. I suspect this issue could be caused by a different Tech in the cars assembly and positioning of wiring harness ( quality control ) as I found our cars wiring was poorly positioned under the central consul when I changed the auto gear selector. Looking at the size of the drain bore I think an aeroquip type braided hose and alloy connector would go on the drain stub and look ok, but may be a bit expensive as its a large'ish bore. When we eventually get home i will have a good root around with a flashlight and see where our cars wiring is positioned, as i suspect the connections are the same, it's just where it's been placed is the issue. dave
Posts: 108 Likes: 24
Posts: 108 Likes: 24 |
Wonder if that was the cause of all my water ingress under front Matt’s 🤷♂️
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Jon the danger is a pipe lets the water fall on the exhaust & turbo. I think I can divert it to the edge of the bonnet but the pipe I have is from a garden water butt so I worry about the plastic melting. As it is it directs hot air directly into the ventilation system. Silicone radiator overflow hose, available in nice preformed bends may be your solution
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Jon the danger is a pipe lets the water fall on the exhaust & turbo. I think I can divert it to the edge of the bonnet but the pipe I have is from a garden water butt so I worry about the plastic melting. As it is it directs hot air directly into the ventilation system. Silicone radiator overflow hose, available in nice preformed bends may be your solution These Hosemaster team are top quality and have never let me down.
