6 members (Doug J, Bitsobrits, Zach, Image, RedThree, Jon G4LJW), 311 guests, and 40 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,356
Christoph
Cover on a 4/4....
A Ford cover us simple to install and solves the problem.
Harald
Harald
That is a nice job
Very nice indeed! Are there any easy/aftermarket solutions for the GDI engine? If I'm right, the Ford cover is suitable for the earlier Duratec engine?
Adam
2019 Green +4 "Toad"
I used a fibreglass coil cover for a Caterham Duratec engine. On the Caterham site they are unbelievably expensive now but someone probably makes a knock-off.
Thanks for all the good comments & especially all the Links etc. I will be forming a shaped aluminium cover the same as DaveW did as a winter project BUT just for the next 2 months I copied what a few others have done & fitted a Ford Duratec plastic cover. Took a lot of “fettling” though 🙄
[Linked Image][Linked Image][Linked Image]
1 member likes this: xc68anc
Thank you for sharing that SteveMerch -- the residual plastic indeed speaks to the amount of fettling required, but still it looks like it took a bit less wizardry than fabricating an aluminium one from scratch!
As I recently mentioned in another thread,I understand that while it is possible to install Focus covers on the older Duratec engines, these will not fit on the GDI models. Or does anyone have experience doing what SteveMerch did, but on a GDI +4?
Adam
