2 members (DJC, Zach), 262 guests, and 57 robots.
Posts837,253
#829665 30/08/25 04:37 PM
hugo Offline OP
Hi , can anyone tell me the part number or size of the auxillary belt on a Zetec 1.8 silvertop (yr 2000 4/4) i cant see any numbers on my belt.
Thanks in advance
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
hugo #829759 01/09/25 11:17 AM
Hugo give BHM a call, they list quite a few auxiliary belts but its hard to isolate the silver top option. They should be able to sort you though. Ford supply two sizes, with or without Air con but don't know if its the standard...... without air con option?
hugo #829793 01/09/25 07:27 PM
All belts are data marked on the outside & it's rare it rubs off, try carefully pushing the car in gear or a couple of dabs on the starter motor to get the belt in another position
hugo #830069 06/09/25 09:17 AM
hugo Offline OP
for reference 6pk913
hugo #830095 06/09/25 08:59 PM
So that's a flat 6 rib belt 913mm long, easy to cross ref any manufacturer now, Gates have a good reputation
