Posts837,266
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
Hi , can anyone tell me the part number or size of the auxillary belt on a Zetec 1.8 silvertop (yr 2000 4/4) i cant see any numbers on my belt. Thanks in advance
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Hugo give BHM a call, they list quite a few auxiliary belts but its hard to isolate the silver top option. They should be able to sort you though. Ford supply two sizes, with or without Air con but don't know if its the standard...... without air con option?
Posts: 8,663 Likes: 488
Posts: 8,663 Likes: 488 |
All belts are data marked on the outside & it's rare it rubs off, try carefully pushing the car in gear or a couple of dabs on the starter motor to get the belt in another position
Posts: 491 Likes: 6
So that's a flat 6 rib belt 913mm long, easy to cross ref any manufacturer now, Gates have a good reputation
