Topics49,841
Posts837,316
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
I was so preoccupied with the central screw nut that I tried your recommendation right away. Pour boiling water over the screw nut... wait two minutes and lo and behold, the nut can be loosened. Thank you, John, for your first-class and quick help 👍 ![[Linked Image]](https://tm-img.com/images/2025/09/28/FullSizeRender9d9865ce4d7cd4e7.jpeg)
Clemens
PlusFour Red Baron MY 2022
1 member likes this:
John V6 |
Posts: 18 Likes: 5
Posts: 18 Likes: 5 |
Anyone know where to buy those sockets in the UK ? My CX came with a flat open hex spanner & a mallet. It sits awfully close to the wire wheel rims, not the best design !! Thanks.. Martin
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
Anyone know where to buy those sockets in the UK ? My CX came with a flat open hex spanner & a mallet. It sits awfully close to the wire wheel rims, not the best design !! Thanks.. Martin Lionel Roberts made various versions for plain and "eared" spinner nuts https://franks4x4-morgantechnical.blogspot.com/2019/11/a-lionel-roberts-alloy-wheel-spinner.html, No longer available direct as far as I know, and I sold mine (sorry) when I switched to eared spinners, but they turn up on line occasionally ![[Linked Image]](https://www.tm-img.com/images/2025/09/28/Special-wheel-nut-tool.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
MartinB60 |
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
Mulfab make angled longer handled versions of your mm one. I have alloys now but am keeping my mulfab and Lionel spanners for now
MartinB60 |
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
I use this brass jobbie, despite years of abuse it works well and very reasonably priced https://shop.mwsint.com/product_details.asp?id=179The pre-warming works too, because the spinners are solid brass and the heat expends them more than the steel threaded hub and cracks open the bond
I made mine myself/had it made. Brexit is unfortunately making exchanges more difficult. But if you like, I can send you a drawing via private message.
Clemens
MartinB60 |
